Though remote work has been in practice for a decent number of years, the pandemic has made businesses take up the challenge of shifting to a completely remote workforce. All this wouldn't have been possible without high-speed internet access for all employees. Another tool that has made the transition smooth and ensured uninterrupted communication is Voice over Internet Protocol (VoIP).
When it was first developed in 1995, VoIP technology aimed to cut down on long-distance and international telephone charges. The first internet phone comprised of software that compressed voice signals, converted them into digital packets, and distributed them over the internet. Further enhancements started in the early 2000s with the evolution of Session Initiation Protocol (SIP), which led to the adoption of hosted VoIP. SIP allowed developers to overcome the limitations of hardware by creating applications that could integrate with almost any phone system. In 2008, 80 percent of all new private branch exchange (PBX) lines installed internationally were VoIP.
With the development of WebRTC, it is now feasible for web developers to enable VoIP in web-based applications. With the development of WebRTC, it is now feasible for web developers to enable VoIP in web-based applications.
Now offering the flexibility of plugging in a VoIP phone to any home router or forwarding calls to personal handsets, VoIP technology has evolved a lot. This hosted VoIP model and the mobile app facility are the reasons that VoIP has lent a helping hand during remote work.
Being low-cost and flexible has always given VoIP services a few brownie points. Modern VoIP systems provide instant messaging, availability information, and remote access to voicemail and fax, on top of forwarding, conferencing, call queueing, speed dialing, transferring, auto-attendants, and video conferencing. This helps even small and medium-sized businesses use VoIP for their communication.
With the less hardware-dependent VoIP systems gaining momentum, as well as the advent of 5G networks, mobile VoIP systems are expecting big growth by 2025, which could have a great impact on how business communications are redefined across sectors. While the BFSI and IT sectors are already using VoIP to the fullest, the healthcare sector is also slowly picking up speed with its VoIP implementations since the lockdown. This, plus the integration with the Internet of Things, clearly indicates how VoIP is maturing based on outlying technology.
Keeping in mind the importance of VoIP and how many organizations have grown dependent on it, it is also important to analyze the technology’s cons. Choppy voices, audio delays, echoes, and voice compression have caused frustration and affected business deals. These problems are common across vendors and are primarily due to network issues. To pinpoint and fix them, it is important to analyze which path of the bidirectional communication is experiencing such errors. VoIP monitoring tools monitor the quality of service (QoS) across the network and call path to identify and fix problems.
Jitter: Jitter, the most common issue, takes place when the packets arrive at the destination in a different order than they were originally sent, resulting in poor or scrambled audio. You can identify the amount of jitter by monitoring the call path and try out methods to eliminate jitter, like using an ethernet cable instead of Wi-Fi, reducing the connections over the same network, limiting the number of simultaneous data transfers, and avoiding bufferbloat.
Latency: Never let your latency go beyond 200ms. Keep an eye on this metric and contact your internet service provider (ISP) if you face prolonged latency issues. You should always have a backup internet connection when your VoIP calls are business-critical. Offices with multiple ISPs easily bypass these kinds of issues. However, for home networks during remote work, ensure that your mobile LTE signals are strong enough to back you up when your broadband lets you down.
MOS: Mean opinion score (MOS) is another key metric that rates the quality of calls. On a scale of 1 (unacceptable) to 5 (excellent), VOIP calls are often in the 3.5 to 4.2 range. Any deviation over a point of time has to be closely tracked and analyzed.
The primary technique to debug and troubleshoot VoIP is to analyze what has been sent and received by the VoIP devices. Monitoring the traffic using a VoIP network monitoring tool is an easy way to accomplish this.
VoIP has emerged as a solution for all types of work irrespective of business sector. You can bear the fruit of the technology only when you use it to the fullest, uninterrupted. And to achieve this uninterrupted communication, VoIP services have to be thoroughly monitored for their quality using performance metrics. Site24x7 VoIP monitoring does exactly this for you by monitoring the call path from the source to the destination, and vice versa, with a dozen metrics.
Visual aids like dashboards and graphs ease your troubleshooting and monitoring, and there are different reports for your stipulated management needs. Set threshold limits for all the metrics and receive instant alerts so you can fix issues right away. Try Site24x7 for uninterrupted VoIP monitoring!
