Monitor OCI Vaults, Keys, and Secrets with Site24x7
Hi there!
We’re excited to introduce Oracle Cloud Infrastructure (OCI) Vault monitoring as part of our OCI integration. OCI Vault monitoring is the practice of tracking the health, availability, and activity of vaults, keys, and secrets in Oracle Cloud Infrastructure to ensure secure and uninterrupted application operations.
As modern applications rely on encrypted data and managed secrets, OCI Vault plays a critical role behind the scenes. It stores encryption keys, credentials, and tokens that applications need to run without interruption. When a vault, key, or secret becomes unavailable, applications can fail fast and security issues may go unnoticed, and OCI’s console level visibility makes early detection harder.
Site24x7’s OCI Vault monitoring brings vaults, keys, and secrets into the same view as your other OCI resources. It helps you track life cycle states, usage activity, and risky changes so you can catch issues early and respond before they affect applications.
Site24x7's integration with OCI Vault provides you with:
  1. Central visibility of vaults, keys, and secrets in one place.
  2. Early detection of misconfigurations or inactive resources.
  3. Reduced risk of application failures due to unavailable keys or secrets.
  4. Better alignment between security operations and cloud monitoring.
  5. Faster troubleshooting by correlating vault issues with other OCI services.
Try Site24x7’s OCI Vault integration to gain consistent visibility, reduce risk from missed changes, and keep your security critical services running smoothly.
Have thoughts or questions? Drop them in the comments below!
Regards,
The Site24x7 team
