Use same IT Automation for multiple status changes
I would like to be able to use the same IT Automation for more than one status change. We use VictorOps Paging service which we setup IT Automations to either send a Critical or Warning Alert to VictorOps. My issue is that I want to be able to use the same "Victorops Critical IT Automation" for both the "Execute on Down" and "Execute on Critical" statuses but the portal will only let me use that IT Automation for only one status. So my current workaround is to create a duplicate IT Automation and just name it something else.
