Setting maintenance using API
Hi there
Is there a way to set-up maintenance using API? Can 'suspend monitor' and 'activate monitor' be used for that purpose and will it then be reflected in the reporting?
Thanks,
Tommy
Topic Participants
tomasz.serafinski
Mohammad Rafee
