I find the PagerDuty integration very limiting when the only options are "All" or "Individuals". Why isn't there an option to target monitor groups? While one could select multiple individual monitors, new monitors would need to be manually added to the integration (and an additional, manual step is going to result in human error and missed alerts).
If one could select groups then collections of monitors would automatically get added to the PagerDuty integration as well.. or address the separate PagerDuty Integration instances as you would a person so they could be added to Alert Groups.
