Network Configuration Manager (NCM)
can now scan your network for firmware vulnerabilities and identify risks based on vulnerability data provided by the NIST.
How it helps
Firmware vulnerabilities
can lead to critical security issues that could put your networks at risk. Network administrators must stay vigilant to protect their network and identify device vulnerabilities quickly.
Site24x7's NCM sends proactive alerts whenever a firmware vulnerability is identified. The Firmware Vulnerabilities Dashboard displays the firmware versions, the number of exposed devices, and the list of vulnerabilities. You can click on any vulnerability to check if a patch is available and check the reference links displayed on the screen to understand how to protect your device against the vulnerability. This minimizes security threats in your network devices and safeguards them against possible exploits.
Get started
Refer to
our help documents
to learn about the prerequisites and other basics you might need to get started.
Feel free to drop your feedback, suggestions, and feature requests in the comments section below.
