Introducing the new Apache Spark monitoring plugin integration
Hello,
We're excited to introduce a new plugin integration to monitor your Apache Spark instances.
Apache Spark is an open-source, distributed data processing framework designed for big data applications. It enables fast, in-memory data computation, supporting diverse workloads like batch processing, streaming, machine learning, and graph processing.
Whether you’re optimizing performance, tracking resource utilization, or diagnosing bottlenecks, this plugin equips you with the insights you need to keep your Spark applications running smoothly.
What does it monitor?
The new plugin covers a wide range of metrics across key Spark components, including:
  • Block Manager: Disk and memory usage, including on-heap and off-heap memory, to help manage storage efficiently.
  • DAG Scheduler: Job and stage statuses, providing clarity on active, running, or failed jobs.
  • Executor Metrics: Garbage collection details, memory usage (heap and off-heap), CPU time, and task statuses to keep your executors optimized.
  • File System Operations: Hadoop Distributed File System (HDFS) and local file I/O metrics, including read/write operations and bytes processed, for data throughput analysis.
  • Thread Pools and Queues: Insights into task execution and queue management for smoother scheduling.
How does it help?
Here’s how this solution empowers your Apache Spark environment:
  • Optimize resource utilization: Stay on top of memory, disk, and CPU usage to allocate resources more effectively.
  • Diagnose performance issues: Pinpoint slow jobs or stages and identify failures with detailed DAG scheduler metrics.
  • Enhance stability: Proactively address resource contention, garbage collection inefficiencies, or dropped events to maintain application reliability.
  • Improve data processing efficiency: Track data read/write operations and shuffle metrics to streamline your extract, transform, and load (ETL) and data pipeline tasks.
  • Gain real-time visibility: Monitor your Spark clusters in real time to stay ahead of potential issues and ensure seamless performance.
Get started
Install the plugin by following the steps outlined in the README on our GitHub repository and start using it today.
We’d love to hear your feedback in the comments!
Happy monitoring,
The Site24x7 team
