Graph configurability for multi-monitor performance widgets
In the documentation for the multi-monitor performance widget, both line graphs and bar graphs are shown. However, when you try to use them, you get either line or bar graphs, and there does not seem to be a way to choose the graph type. It would be good to have a switch or setting to enable the choice of bar or line graph.
