Extreme Networks VSP7400 note recognising interfaces or reporting CPU & Power in the readily available template
Hi,
Just wondering if anyone has any experience with adding Extreme Networks switches to 24x7. Some I have had no issue, EXOS and VSP based switches.
One model I am having an issue is with the VSP7400. There is a template available for this, but on discovery no interfaces are detected.
The template also looks like it comes with OID's configured for CPU, power supplies, memory usage, but none seem to work.
The switch is recognised, shows up and run this tool also:
support.site24x7.com/portal/en/kb/articles/to-check-the-snmp-reachability-using-mib-browser
The output is as follows:
sysObjectID.0:-->.iso.org.dod.internet.private.enterprises.1916.2.325
I can also use the standard MIB to pull all the interfaces, so from what I can tell, it should have no issue reporting and discovery all the relevant elements?
Appreciate any help in advance.
