Monitor Oracle Cloud Infrastructure (OCI) Dynamic Routing Gateway with Site24x7
Hi there!
We’re excited to introduce Oracle Cloud Infrastructure (OCI) Dynamic Routing Gateway (DRG) monitoring as part of our OCI integration. OCI Dynamic Routing Gateway acts as a virtual router that connects your on-premises networks, virtual cloud networks (VCNs), and other cloud environments securely and efficiently.
With Site24x7’s integration for OCI DRG, you can now gain complete visibility into your network connectivity across Oracle Cloud. Integrate your DRG with Site24x7 and leverage the following benefits:
  1. End-to-end visibility: Gain continuous insight into the DRG and its connected resources.
  2. Faster issue resolution: Quickly detect and fix connectivity problems between VCNs, on-premises networks, and remote peers.
  3. Error prevention: Monitor DRG attachments, route tables, and route distributions to avoid routing errors and policy misconfigurations.
  4. Reliable connectivity: Improve the stability of hybrid, cloud, and multiregional setups by ensuring consistent traffic flow.
This visibility is key to identifying network bottlenecks, optimizing data flow, and maintaining uninterrupted communication across your on-premises and cloud environments.
Start monitoring your OCI DRG with Site24x7 today to keep your network connections reliable and your cloud operations running smoothly.
Have thoughts or questions? Drop them in the comments below!
Regards,
The Site24x7 team
