Custom metric widgets for text and codes
Hi,
I have a use case where I would like to put a widget that holds a single value or word as a metric.
i.e. status code for HTTP response, or True / False for a database connection.
Ideally it is linked to a threshold, so that when ok it is green, when alert it is orange and when critical it is red.
example of this is attached for reference.
