Create configuration profiles for APM Insight applications
Greetings,
Configuration profiles can help edit default agent configurations like threshold values for traces, APDEX, sampling factor and more to suit your monitoring needs.
Highlights:
  1. You can apply the same configuration profile across multiple applications: You need not create or edit a profile whenever you add a new application. You can use the existing profile for multiple applications.
  2. Avoid the hassle of instance-wise configuration: Since configuration profiles are executed at the application level, they are applied to application instances as well.
Learn how to add agent configuration profiles in APM Insight.
For any questions or concerns, leave us a comment below and we’ll get back to you
