Hi Site24x7 Team,
is it possible to configure a check (monitor) for cipher configuration?
Site24x7 should check which ciphers the server returns for xyz.website.com and compare them with the specified ones.
If something does not match, it should send a message.
(Screenshot of SSLLABS.com)
I found to "Add an SSL/TLS Certificate Monitor", but this checks only validity and expiration of the TLS certificate.
Kind regards and thanks for your help,
Fabian
