Alert only when two (ore more) Threshold are on Warning or Critical on same monitor
it could be great to have a new feature :
Today when one Threshold is reached a trouble is generated, sometime it's interresting to get only alert in cas of Two Threshold are reached
exemple SQL: when "Page Writes exceeds 90 per second" is's not not enought to determine is there is a real issue, you need to correlate with pages fault per seconds on Disk
Emmanuel
