We have a number of servers that have tags assigned.
There are two types of tags that have been assigned
User Defined Tags - these are added and removed manually by ourselves
System Tags - these have been added automatically when the servers were created in Azure (auto populated from the Azure Tags).
System Tags cannot be added/removed from within the edit monitor screen. Been advised this can be done using a bulk action but this is difficult as there is no filter option to select between system and user tags (Bulk Actions).
Can the ability to filter by system tags and user defined tags be added?
Could the same ability to add/delete system tags as currently available with user defined tags be added
The reason for the request is that we have migrated a number of azure based servers to on-prem virtual environment therefore the auto assigned Azure system tags are no longer relevent and need to be deleted.
